Old 09-05-2012, 12:57 PM   #2
Eric G
Theoretical propagandist
Eric G's Avatar
Originally Posted by sasha055 View Post
Thanks,
I indeed replaced only the main one.
I'll check the other two.
Is there a write-up on how to access/change the other two?
Sasha
It's ugly for the first hose and how you get to it is through this write up: Pelican Technical Article: Boxster Coolant Tank Replacement - 986 / 987
So you might want to consider doing the coolant tank while your at it...if its old.
Advise is to remove the clam shell as it will give you more room to work around if your going to dig in deep. When you replaced the main tube did you remember to install the O-ring back on the end of it?
