Old 11-17-2005, 10:57 AM   #2
bigwatts
If it is the window regulator how much can I expect to pay for labor at an independent shop. How long will it function (in the grinding noise way) before it ceases to work.
Can this be replaced by someone with decent mechanical knowledge. I assume its pretty much just removal of the door panel then replacing the regualtor. Is this correct? Has anyone done this job before?
I found this link that details how to remove the door panel. http://www.ecoutez.net/boxster/door-panel-removal/
I assume its pretty much the same for a 97 boxster , minus the side airbag part. How hard is the regulator to replace once the door panel is off?
Thanks in advance for your help.
bigwatts is offline   Reply With Quote
