Old 09-03-2012, 05:11 PM   #10
Dave S.
Dave S.'s Avatar
Originally Posted by embryoguy@mac.com View Post
dave, how did you remove the green fact housing to keep the cable tension? just dremel it off? mine was intact.
The green end of the cable sleeve was intact on mine, but it didn't fit well with the barrel adjuster I was using, so I cut it off. I think I just used a plier-like cable cutter to break it up and get it off the cable.
If it fits into the barrel adjuster you are using, you might want to leave it on there.
Dave S.
2003 Boxster S
Dave S. is offline   Reply With Quote
