Old 08-31-2012, 04:47 PM   #11
Focusyn
Sorry for the quasi-hijack BigSmoothLee - but it's related, and not necessarily a hijack - the numbers imply that going to 17's, which I think should fit around your S model brakes depending on year of your car/brakes, will still result in a potentially high gain in acceleration torque in the speed ranges you're doing in autocross assuming spec tire sizes...
Thanks be to you and Topless for giving me a keen idea for a new component to build in to my home-brew Porsche software
Previous post about the numbers was off the top of my head and I totally mis-stated the revolutions per mile - I did the math in my head without the numbers in front of me, and I mistakenly based distance per rotation on the diameter and not the circumference. Oops again. Also put the front wheel aspect ratio of the 16 in that post (55) instead of the rear, which is 50, and is accurate in the numbers below.
It turns out that per mile, the 16" rim/tire combo needs to spin just under 20 additional full revolutions over the 19", i.e. more low-end torque and faster low-end acceleration but lower speed at rpm limit for any given gear.
Here's the math:
Constants used for calculation:
pi = 3.1415926535897932384626433832795
1 mile, in inches = 63,360
rotations or revolutions refer to (1) full rotation of
the tire, NOT engine rpms
Recommended / Approved tire sizes based on rear wheel summer tires from 2000
model year owner's manual for 986/986S for 16-18" sizes. No 19" sizes
are approved or recommended for 2000 model year, so I used the actual rear wheel tire size on my particular car. I picked 2000 because that's the only manual I have handy, but I believe the general trends will apply to most if not all other model years due to the Deutsche formulas Porsche uses to calculate their recommendations.
With transaxle RWD, REAR wheel tire rotations are directly proportional to engine rpms, regardless of actual gear/final sizes - that's why I stuck with tire rotations and not engine rpms, as those will vary with your partiular gearing. As the engine
spins several times per rotation, differences would appear much more significant
if calculated as engine rpms using actual gear/final constants. I am an engineer but not a mechanical one, so frankly I just don't know all the math that goes in to calculating it that way off the top of my head.
Sorry for the huge numbers of decimals making it a bit of a bear to follow, but to calculate deviations or trending accurately requires a high level of precision in variables. If you do enough rounding, you will end up with equal numbers (for example if I rounded all the OD's to 25" instead of leaving the high precision numbers in there ).
I got lazy and used Google to make the conversions from
mm to inches for section, so actual deviations may vary very slightly depending
on the precision of their conversion algorithm variables.
225/50/16
225/50 = 4.429135" section height
* 2.000000 (account for section height on top and bottom in total diameter)
8.85827" (total diameter added by sidewall/tread)
+16.00000" (rim diameter)
24.85827" total OUTER DIAMETER
Circumference = 2π(24.85827/2) = (6.283185307179586476925286766559)(12.429135")
OR Circumferece = 78.094558412951549565878774135275" distance travelled per revolution
OR, this rim/tire combo needs to spin 811.32413432652300214910170718101
times to travel 1 mile
OR, this combo travels 1.2325530052549171332998543897612 miles per 1,000 rotations
255/40/17 =
225/40 = 4.01575" section height
*2.0
8.03150"
+17.00000"
25.03150" OD
Circ = 2π(25.03150/2) = (6.283185307179586476925286766559)(12.51575")
or 78.638776508332909448577657848561" per revolution
or 805.70938172322781090357950960051 wheel revolutions per mile
OR, this combo travels 1.2411423060027290001353797008927 miles per 1,000 rotations
265/35/18 =
265/35 = 3.6515748" section height
*2.0000000
7.3031496"
+18.0000000"
25.3031496" OD
Circ = 2π(25.3031496/2) = (6.283185307179586476925286766559)(12.6515748")
or 79.492188896043515345888739538571" per revolution
or 797.0594454614842473457513958881 wheel revolutions per mile
OR, this combo travels 1.2546115671724039669490015710002 miles per 1,000 revs
275/30/19 =
275/30 = 3.248031" section height
*2.000000
6.496062"
+19.000000"
25.496062" OD
Circ= 2π(25.496062/2) = (6.283185307179586476925286766559)(12.748031")
or 80.098241074669890975024340383984" per revolution
or 791.02860624534788739660856231704 wheel revolutions per mile
OR, this combo travels 1.2641767846380980267522780994946 miles per 1,000 revolutions
Focusyn is offline   Reply With Quote
