Old 08-30-2012, 08:50 PM   #4
thstone
Originally Posted by SeanZ4 View Post
I find those little brown plastic things in my filter from time to time. I was told that they may have been gasket material or something?? I installed the magnetic plug from pelican and only have found just a small amount of very fine metal sludge. I change my oil at less than 3k though.
good luck
sean
Yes, the little brown or yellow bits are excess gasket material that squished out on the inside of the engine when the surfaces were mated and they have finally broke off. No big worry.
The metal debris is worrisome. Good engines don't normally lose metal bits through normal operation. I would look into that.
