Old 08-30-2012, 07:24 PM   #1
Eric523
Boxster Abuser
Eric523's Avatar
The box has had steel synchs and the Albins short 3-6 gears installed. I added a G50 diff with GT parts and changed out the stub axels. Also added a transmission cooler provisions to use my existing system. To use the 6-speed box in an early Boxster, I had to get some new trans mounts, some Boxster S rear uprights, and some Boxster S axles.
gear chart - http://californiamotorsports.net/996%20Boxster%20S%20986%20short%203rd-6th%20gears.pdf
In between the two will be a new AASCO flywheel and Tilton 7.25" twin disc metallic clutch unit.
Eric523 is offline   Reply With Quote
