Hi,
My suggestion is to get a proper purchase as BL suggests. Then drive the Car As Is for several months. This will familiarize you with the Car and give you a better understanding of which Mods will be the most important to You.
This will also give you some time to recover from the Purchase Shock and to Shake Down the Car and correct those Mundane, Non-Sexy, things which may require your $$. No point in doing a bunch of Mods and then find out you need Plugs, Oil Change, Alignment, Clutch, Window Adjustment, Top Adjustment, etc, only to find out that you've already busted the Bank on non-essential items.
Happy Motoring!... Jim'99
