Thread: Do I have RMS?
Old 08-27-2012, 05:04 AM   #10
jlawrence54
Originally Posted by Steve Tinker View Post
What does your coolant level look like?
If its higher than normal and contains oil resedue, you have a problem.....
Was the engine cool when you checked the oil - it sometimes takes 10 minutes for the oil level to stabalise after a hot run.
Thanks for the reply. I didn't check the coolant for level or contamination, I will when I get home tonight. Yes, I checked the oil the next day. Both the dash oil level gauge and the manual stick barely indicate a reading. Somehow I misplaced ~9 quarts of oil in 170 miles (85 each way). I believe my nest step will be to drain the pan and see how much is there. Assuming the coolant is OK and the oil drain produces a couple of quarts, I suspect I have a hosed RMS.
jlawrence54 is offline   Reply With Quote
