Thread: Sticky Throttle
Old 08-22-2012, 09:43 AM   #1
BYprodriver
BYprodriver's Avatar
Originally Posted by tanque55 View Post
Thanks I'll look into that. Although I've wrenched every car, truck and motorcycle I've ever had, I'm a little intimidated with this one. Just getting to the engine seems complicated. I need to get me some manuals any bible that you suggest?
Cleaning the T/B is the 1st thing you should do, Porsche eliminated throttle cables in 2000. The Bentley publishers manual is a good start. With your experience just remove the top engine cover & you will see the T/B right there, remove intake tube & clean with Brake cleaner. You can hold the throttle open with your fingers & scrub inside with a clean rag. This does wonders for your idle speed.
