Thread: Boxster Hood
Old 08-17-2012, 07:19 AM   #13
Topless
Track rat
Topless's Avatar
Originally Posted by flinteruk View Post
Morning all
I am getting into this DIY repair now !!
Have found the relays ( big deal I hear ! ) , and have pulled out and tapped the relay hard a few times ( part no 98661811102 ) , no change , totally dead , not a whirr from anywhere. Should I now buy a new relay ( I see the buggers are the dearest at around £80 a piece !!! ) and fit it or might I be throwing money away ? Any other tests I can do , I am in the zone now :-)
Do you understand how to test a relay? If you are not comfortable doing this, take it to someone who is for testing. Also pull the fuses and check the one for the top. It should be 0 ohms/closed.
1. Energize the coil with 12v and test across the load terminals for continuity. Should be 0 ohms.
2. De-energize the coil and test load side. Should be open circuit.
This is a duplex relay so I am guessing one side is for raising the top and the other side is for lowering.
