Old 11-11-2005, 06:39 AM   #21
deliriousga
deliriousga's Avatar
Originally Posted by blinkwatt
What do you connect to the outside bleeder screw to let the old brake fluid drain through?
Some clear tubing (aka surgical tubint). You can get it at most auto stores or a hardware store. I think the inner diameter is about 1/4"-3/8". It doesn't have to be perfect, just big enough to get it on there and small enough to keep fluid from leaking out. Get about 4' of it so you don't have to worry about the catch can falling over because it's right next to your feet.
When using the power bleeder, I put the new fluid in the power bleeder tank and run the tube from the bleeder screw into the empty brake fluid can so there's nothing to clean later.
1966 Wife White/Brown Top
