Old 08-10-2012, 07:05 AM   #1
Topless
Track rat
Topless's Avatar
Originally Posted by jaykay View Post
I am always wondering what to with the Boxster and fire suppression. I try and run with everything but the engine cover off so there is potential to get to the engine bay in time. It would be nice to find a reasonably priced fire suppression system that could hit the fuel rails area at the first sign of smoke....fired from the coockpit
Currently our track fire safety crew recommends aqueous foam extinguishers (AFFF) and NOT removing the engine cover in case of fire. If you open the engine cover it creates a chimney effect that multiplies the size of the fire. It also puts you at much greater risk of injury. You can hit everything from underneath the wheel wells and aqueous foam is water based so it cools the components below the flash point.
In the case of the 2008 Cayman, he was running with a different club at the time. They used dry extinguishers and the fire re-ignited several times because they never got it cooled it down. When they did open the engine bay, flames went 20 feet in the air.
Car fires are bad news.
