Old 08-03-2012, 04:30 PM   #1
pothole
I fail to see how higher rev clutch engagement minimizes wear.
Whether the revs are high or low is notthe issue.
It's whether the revs match road speed when you re-engage the clutch. When you change up it's not an issue so long as you make your changes reasonably rapidly. You lift off and push the clutch, the revs begin to drop, but you're already selecting the next gear and re-engaging the clutch. When you select a higher gear, the result is lower revs for a given road speed, so road speed and revs are naturally fairly closely matched as you complete an upshift - or pretty much perfectly matched if you know what you're doing.
On a downshift, you're selecting a lower gear which means higher revs for whatever road speed you're doing. If you just change gear without rev matching via the throttle, it'll be clutch friction that lifts the engine speed to match road speed. A blip on the throttle as you change gears, however, can match the two and if done well the wear on the clutch for a downshift is close to zero.
What you're aiming for is gear changes where you cannot feel the clutch engaging. The change is completely smooth.
If you do this, you'll dramatically increase the life of your clutch.
The big difference in clutch life in these cars is down to how they're driven and not the traffic or road conditions. Same goes for supercars. You hear about people getting through clutches in exotica in 5k miles, which sounds ridiculous.
But this isn't because they're driven hard or because the clutches have silly low life spans. It's because they're driven badly and in a supercar the loads are very high, so when you don't change gear properly, the wear rates are horrific.
Rev match all your shifts and you can spend all your time on track days and still wear the clutch less than some other guy who just pootles around town but can't change gear properly.
pothole is offline   Reply With Quote
