Old 08-03-2012, 02:08 AM   #2
Bruce Wayne
Bruce Wayne's Avatar
i use a pressure washer from time to time you also have to be careful of any stonechips (around the rear of the front wheelarches) as any paint chip can get lifted quickly by pressure.
i also use two sponges and alternate, leaving one to soak while i'm using the other one,i also give them a shake before each pick up.
The method i use is front, driver side, passeneger side, rear then wheels that way you're going lighter dirt level to higher..
i dont pressure wash the wheels or use chemicals, just warm soapy water i also never use a drying blade as any grit that lands on the car will get dragged down the paint by the blade.
i'm a big fan of the autoglym range for paint care and use the wheel seal on the wheels.
986 x2 6sp
2x Range Rover Vogue 4.6
2004 MX5 Sport 6speed Strato Blue (wifelet)
2x Range Rover Classic & CSK
Bruce Wayne is offline   Reply With Quote
