Old 08-02-2012, 04:15 PM   #1
m12volt
Originally Posted by pothole View Post
I'd be checking the MAF specifically and the induction generally for airleaks.
Take the engine cover off, check for leaks, broken clips, etc. If nothing obvious, unplug the MAF and take it for a run. If it makes no difference, that will eliminate both leaks and MAF from the equation.
Disconnected MAF , took it for run , much , much better , almost perfect.
Obviously MAF needs to be replaced , what would be your suggestion , OEM or replacement? Very big price difference...
m12volt is offline   Reply With Quote
