Old 07-30-2012, 12:39 PM   #2
jaykay
jaykay's Avatar
I am pretty sure it is not, & oil temp is based on coolant temp. I assume you can verify this by comparing the 2 temps & see if you can achieve a different number for the 2 fluids.
I didn't record the session but I do recall "engine temperature" matching my water temp gauge indication very closely at idle with the oil temp lagging behind with the car idling up to a water temperature of 80C (180F). There seemed to be a 10C spread up to that point....with the car sitting still and idling. It looked promising to me. Perhaps those with lots of "data" experience could comment.
I believe I have seen this oil temp probe on a schematic long ago and the lead appeared to go the the ECU with its location down away from the heads. I will try and post it if I find it.
Perhaps Chris has a later version DME software where the oil temp is locked up.....can't recall his model year. Oil temp was right there being actively read on the session I ran!
986 00S
