Old 07-22-2012, 04:17 PM   #1
Spinnaker
Spinnaker's Avatar
Are you any good with a volt meter? You need to determine if there is any voltage at the bulbs. If not, then you need to start tracing back through the circuit to find the fault. Check the grounds also.
Just a guess, but maybe when you swapped out to the LED's, you may have bent a pin in a connector or broken a wire. Happens all the time.
