Old 07-20-2012, 11:20 AM   #10
jb92563
jb92563's Avatar
Originally Posted by SoK View Post
soooo it sounds like wiring should be plug and play (for speakers) with this unit, is that right?
I'll mess with the backup camera when the car's apart, doesn't sound too bad to do once we're able to easily ID (hopefully with pics) something to wire it into for reverse.
So at this point, finding a cage for this $200 unit is the hangup..
Yes, Plug and play for the speakers, power, Illumination(headlights on signal)
Power + (Yellow),Ground - (Black) , Illumination (Orange), Switched + (Red)
You cut midway through the middle mounting hole and tray seperator. Don't need to cut the top one.
8.5" (216mm) deep slot for the double DIN radio.
The included plastic faceplate(Not shown) will cover the entire width but the part above needs a cover. More on that to come.
The Yellow connector has the speakers on it if you have a factory Amp, but there is a Brown connector instead (Not in this pic) if you dont have an Amp, with your speaker connections.
