Old 11-06-2005, 09:18 AM   #32
97Boxsterian
Originally Posted by olly986
hi boxsterian
the mass airflow problem I had did not show on any dashboard light and as you mention the hard starting there is an explanation on your other thread about right amount of air for fuel to ignite your engine, I believe the airflow is more than likely your start problem
I agree with you. I plan to clean MAF first and see if the problem goes away. If not, I will replace it. Thanks for your opinion!
97Boxsterian is offline   Reply With Quote
