Wheel Bearing Replacement
Just finished with the front wheel bearings last weekend and did the rears about 2 months ago. This is a 2002 S with 43,000 mi. The fronts were not sounding too bad but the rear sounded so quiet after replacing them I went ahead and did them too. One of the local Car Quest had a machine shop and it was well worth letting them press out the old bearings and press in the new. I would recommend using a ball joint press instead of a fork (split the ball joint cover. A coil spring compressor was helpful in removing hubs. I do a lot of auto work so I believe in only buying good tools. An exception being the ball joint press from Harbor Freight. Cheap and did the job just fine.
