I did mine last month on the two front wheels. I removed the wheel hubs and have a friend with a hydraulic press in his garage pressed out the old ones and put the new ones. You can use the bearing puller with the hub still on the car but installing the new bearing was a little harder making sure it sits centered and the two inner races are not misaligned. I am sure you can find shops in your area with a press. Pelican had detailed the steps in doing this also. Good luck!
