Old 06-26-2012, 08:24 PM   #1
copsahl
copsahl's Avatar
From a Pelican Parts tech article:
If you install an aftermarket seat in your car, you will initially have a problem with the airbag computer giving you errors. You need to reprogram the computer (using the Porsche factory PST-2 or PIWIS) to ignore the error signals. The late model cars with side airbags in the seat also need to be disabled. If you use a five-point harness with your seats, then you will need to disable the seat belt sensors. Finally, you need to turn off the Automatic Weight Sensor (AWS) for the passenger seat. If you take your car to the Porsche dealer or an independent with the PIWIS tool, then it should take about 20-30 minutes for them to reprogram the air bag controller for you.
copsahl is offline   Reply With Quote
