Old 06-25-2012, 10:55 PM   #2
sb01box
My 01 with lumbar adjust had a problem where if during hard right turn the lumbar adjustment would happen by itself. Taking the switch plate off, I found the electrical wiring was rubbing along the seat rail (at the left thigh support) and the insulation had been compromised, Additional pressure on the thigh support by a heavy driver!s left thigh was inducing electrical connection.
You may want to see if similar thing is happening with your seat with the hot side wiring.
Good luck
sb01box is offline   Reply With Quote
