Old 06-23-2012, 01:42 PM   #14
fredpayne
fredpayne's Avatar
I have no clue I haven't tried either one of them, however, after doing a lot of research, I don't think you need either one, the T shape of the factory plenum does it as well as anything since the air flow is not constant, without constant air flow the Y in the tube serves no useful purpose. The Boxster engine works and acts like 2 seperate connected 3 cylinder engines and I see no advantage to a 74mm throttle body or either plenum, IPD's or Pedro's. It would be like putting a 750 Holley double pumper on a 283 engine, not only an overkill but will reduce power, especially in this analogy since all you may need is a 500 Rochester or at most a 650 double pumper, I'm leaving mine as is, I figure the Porsche engineers are pretty smart. I have had my ECU flashed and have a Borla catback exhaust, that's about all I need.
Originally Posted by wawa View Post
How does it compare with the Pedro techn o torque? at more then twice the price, is it worth it?
wawa
2003 Boxster S - Orient Red
2010 Toyota RAV4
Past Toys
2000 Boxster - Ocean Blue
1994 Toyota Supra 320HP
1987 Porsche 944S
1983 Porsche 911 Carrera
1980 Porsche 911 SC
1976 Trans Am 455 Cu.In.
1962 Corvette Convertible
1957 Pontiac 2DR HT 421 Cu.In.
fredpayne is offline   Reply With Quote
