Old 06-21-2012, 06:58 AM   #3
jim_hoyland
jim_hoyland's Avatar
As it is the rear tires, I'm thinking cupping resulting from under inflation might be more likely than alignment.
Replaced the rears at Grand Prix Performance yesterday. They called it cupping and I had been inflating them to 32 lbs. Tomorrow, they are doing an alignment, the tech said it was close, but better to dial it in.
Several sources recommend replacing OEM shocks at 50K, I have 54K on the '98 base model. It's all been generic driving, no AX, no spirited driving. When I push down on the body -at the corners- the rebound is stiff, and the car never rolls on curves. I assume the shocks are fine....
jim_hoyland is offline   Reply With Quote
