If you have a Check Enging Light and need to access the code(s) that are causing the problem, find an AutoZone and borrow their reader. I know,,,,I did this two days ago. You will have to put up a $170.00 deposit (plus tax), to borrow it. Some have suggested that you can ask people at AutoZone to read it for you, but according to CA laws, they are technically not allowed.
Anyway,,,,the entire check took 2 minutes. Once you have the codes, you can erase them with the reader. Then take the reader back and they will credit your card the full amount.
IF you drive the car to the store, you can do the check in the parking lot and return the reader immediately.
FYI, the adapter port is above the fuse box on the left!
Mike
