Old 06-18-2012, 06:36 PM   #2
Johnny Danger
Johnny Danger's Avatar
Originally Posted by jacabean View Post
last year I bought a set of 19"techart formula replica wheels . so i finally got around to getting some rubber for them (Hankook ventus evo) . I am looking at the rubber bands sitting in my living room thinking how the F are these going feel and how long they are going to last until a wheel gets smashed. any comments on the 30 profile rear tires ? i also test fit one rear wheel without the tires on them , they are 60 et and i got a 15mm spacer but there is less than a 1/4" room from the strut. are these going to rub when the tires are mounted ? i'm fearing a 19" failure !
Assuming that these wheels are 10 inches wide, +45 is about the highest offset that you can have before inner clearance becomes a problem . At this point, I would not recommend using a tire any wider than 275 . Furthermore, if you can bring the offset down to +40, needless to say, you'll have much better clearance . As far as 30 profile tires are concerned, if you want to have 19 inch wheels - you have to sacrifice some "cushion" .
