Old 06-18-2012, 09:02 AM   #11
grubinski
I find it helpful to make sure the throttle is at least cracked open a bit (not fully closed, even if you are still braking) as you let the clutch out. That way, if you have missed slightly low on the revs when you blipped, you don't upset the car with engine braking due to a closed throttle in the lower gear.
grubinski is offline   Reply With Quote
