Old 06-18-2012, 07:27 AM   #10
Frodo
I'm not recommending double clutching, my method uses the clutch just once, just blip as you are going through neutral. Its no slower than putting it in the lower gear first, then blipping, it actually faster, you are doing two things at once, blipping the throttle and moving the gear shift.
And blipping while going through neutral does save a modern synchro mesh tranny. Even with the clutch depressed, there is some drag in the clutch and blipping the throttle while in neutral will spin up the input shaft some, which means the synchro has to do less work.
I'm pretty much positive I'm over-thinking this...but I have to ask: When you're doing this your way (blipping as you are going through neutral---presumably you're talking about the instant before down-shifting), do you again blip as you release the clutch? Or is it just one longish blip that both meshes the synchros (as you down-shift) and makes for a smooth transition as the clutch is released in the lower gear?
