Old 06-15-2012, 12:11 PM   #4
BYprodriver
BYprodriver's Avatar
If the bumps are that small it could be caused by worn struts or the alignment being off.
All tires have a date code at the end of the serial number after the DOT the stamped number is 4 digets & the last diget is the year.
Serial # is molded onto the tire, date code is stamped after the molded #
Another sign the tire rubber is hardening is cracks in the rubber. Worst place is right next to the wheel rim
