Old 06-10-2012, 07:04 AM   #21
pothole
I'm not recommending double clutching, my method uses the clutch just once, just blip as you are going through neutral. Its no slower than putting it in the lower gear first, then blipping, it actually faster, you are doing two things at once, blipping the throttle and moving the gear shift.
And blipping while going through neutral does save a modern synchro mesh tranny. Even with the clutch depressed, there is some drag in the clutch and blipping the throttle while in neutral will spin up the input shaft some, which means the synchro has to do less work.
The problem with your position is that gearbox failures are pretty rare on modern cars. So it's simply not necessary to shift using your method.
I'd also dispute whether it's faster using your method or even if it's practical as you describe to blip literally within that tiny window as the box goes through neutral on a fast downshift. I'd have to see some video or preferable a first hand demo to really gauge what I thought.
pothole is offline   Reply With Quote
