Old 06-10-2012, 06:41 AM   #20
san rensho
Originally Posted by shadrach74 View Post
If the goal is smooth and quick shifts, than yes that extra step does take time and smoothness away from the process. The whole point of a heel and toe when driving is to match the engine speed to transmission speed for the gear I'm moving into. The clutch must be released at the precise moment the engine reaches that speed. What you are talking about is double clutching. It is necessary in older non-syncro crash boxes to blip the throttle in neutral. Today in a modern car, it's not needed, nor will it trash a gear box, it may be easier on the syncros, but it's not necessary...nor is it a recipe for quick/smooth shifts...
I'm not recommending double clutching, my method uses the clutch just once, just blip as you are going through neutral. Its no slower than putting it in the lower gear first, then blipping, it actually faster, you are doing two things at once, blipping the throttle and moving the gear shift.
And blipping while going through neutral does save a modern synchro mesh tranny. Even with the clutch depressed, there is some drag in the clutch and blipping the throttle while in neutral will spin up the input shaft some, which means the synchro has to do less work.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
