Old 06-04-2012, 07:42 PM   #3
seventythree
Originally Posted by blue2000s View Post
I mounted my cushions so that the rubber side faced the mount. I assume that you want the rubber facing the part that is likely to come into contact with it.
Your first picture shows the mount but no aluminum housing. Did you push it out?
Well, the stop gets sandwiched between the mount and the carrier, where otherwise there would be metal to metal contact when the rubber bushing flexes too far. So, I am still not clear on how the hybrid stop is supposed to make a difference.
As for the bushing in the pic, I only bought the bushing from Pelican and pressed it in. It worked out OK only because I have a 10 ton, shop grade, hydrolic press at home. Otherwise, it would've been impossible. Without a press, or even with a cheapo version from Harbor Freight, one shouldn't attempt it. It's a pretty hard push.
seventythree is offline   Reply With Quote
