Old 06-01-2012, 06:21 AM   #5
jcb986
jcb986's Avatar
60,000 Mile Service
Diagnose/Test
Data Link Connector
Diagnosis system: Read out fault memory.
Inspect
Axle Shaft
Drive shafts: Visual inspection of boots for leakage and damage.
Brake Fluid
Brake Hose/Line
Brake hoses and lines: Visual inspection for damage, routing and corrosion.
Brakes and Traction Control
Visual inspection of the brake pads and brake discs for wear.
Clutch, M/T
Check play and pedal end position.
Constant Velocity Joint
Check play, visual inspection of dust bellows for damage, check screw connections of running gear adjustment facility, front and rear, for secure fit.
Coolant
Check coolant level and antifreeze protection.
Cooling System
Coolant hoses: Check condition; Radiator: Visual inspection for external contamination.
Doors, Hood and Trunk
Check the door locks, lid locks and safety hooks of the front lid to ensure that they are secure and functioning.
Exhaust System
Visual inspection for leaks and damage, check suspension.
Fluids
Oils, fluids: Visual inspection for leaks.
Fuel Delivery and Air Induction
Fuel system: Visual inspection for damage, routing and secure fit of line connections.
Instrument Panel, Gauges and Warning Indicators
All other electrical equipment as well as warning and indicator lights: Check function.
Lighting and Horns
Vehicle lighting: Check funtion; All headlamps: Check alignment. Horn: Check function.
Parking Brake System
Check free play of parking brake lever.
Power Steering Fluid
Seat Belt Systems
Check function and condition.
Steering Gear
Check play and dust bellows.
Throttle Cable/Linkage
Throttle actuation: Check smooth operation, check full throttle position with the tester.
Tie Rod
Tires
Check condition and pressure, include spare wheel.
Vehicle
Vehicle underside and engine compartment: Visual inspection for leaks (oils and fluids) and chafing damage (lines and hoses). Test drive: Foot and parking brakes (also actuation travel), engine, clutch, transmission, automatic speed control, steering, heating, air-conditioning system and instruments: Check function.
Wiper and Washer Systems
Windscreen washer, headlight washer: Check the fluid level and nozzle settings, pay attention to antifreeze protection in the winter.
Replace
Air Filter Element
Cabin Air Filter
Drive Belt
Replace Poyrib belt.
Engine Oil
Oil Filter, Engine
Spark Plug
Dealers charge between $1200 - $1500.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
