Old 05-21-2012, 10:00 AM   #2
black_box
DIY extremist
black_box's Avatar
Originally Posted by ToddPhilly View Post
Quick question - how difficult was it to replace the e-brake microswitch? I think mine is shot. If you put any weight (i.e. rest your arm on) on the e-brake while disengaged, the light will come on in the dash. Was thinking of replacing the switch. Difficult to do?
It was actually super-easy.
If you have the problem I had, and it was stuck in the OFF position and preventing the top from operating, and you want to cheat a little bit in the meantime, you can, with no tools, trick the car into thinking the e-brake is on by pulling off the lever cover, pulling out the plug from the microswitch and putting a paperclip into it. Then fix at your leisure.
"Betty" -- 2000 Boxster S, Triple Black, loaded except PSM (sold to a good home)
"Veronica" -- 2008 Boxster S, Arctic Silver on Blue
"Maleficent" -- 2007 Cayman S, Red and Black, TPC Turbo 3.6L 460 RWHP, H&R RSS Coilover / TPC stage 2 suspension
black_box is offline   Reply With Quote
