Old 05-18-2012, 03:01 AM   #13
2003S
2003S's Avatar
Originally Posted by ferrytrip1 View Post
When I connect the clamshell pushrods the passenger side is a little jerky and it seems to struggle unless I give the clamshell a bit of a helping hand.
Could I be back to the motor struggling under load?
I don't think it's a load issue, both sides are driven by the same motor. Could the passenger side transmission arm just be slightly out of alignment relative to the drivers? That might cause the clamshell to be 'twisted' slightly causing what you've described?
You can disconnect the drive cable on one side, the move the motor slightly/ reattach cable to get them realigned.
2003 Midnight Blue S
LN IMS Retrofit
