Old 05-17-2012, 05:19 AM   #20
ProjectM96
For the second time, the inner shields are adjustable. Remove your wheel(s), and look behind the shields . You'll discover that the tabs (or whatever they're called) can be adjusted to allow them to be moved inward toward the bumper . This should create enough space for the tires to clear .
I didn't notice the tabs when I looked. I was trying to adjust it like you said before I posted this picture. I guess I will take the wheels off and check it out again later.
In other news, because of my clogged A/C lines and the hard rain in Philly the other day, I literally had about 4 gallons of water under my passenger seat. I vacuumed most of it out. I also found a couple of tobacco products under my carpet under the passenger seat and the water had a white powerdery substance floating in it?!?!
00 2.7 5SPD MT
ProjectM96 is offline   Reply With Quote
