Old 05-15-2012, 06:05 AM   #1
Andrew McD
Andrew McD's Avatar
Hi, I'd much the same problem. I'd the MAF changed and leaking oil filler pipe changed. Seems as if the vacuum leak from the oil filler tube was causing all sorts of problems to performance, but I also found out a vac leak can have real problems for how the tip makes its changes. A totally different car now.
Twitter if anyone is interested... @JAZ5788_Boxster
Boxster 2.7 with a few mods: RSS Under drive pulley, Dansk OEM look polished stainless steel sports silencer, K&N air filter, Full new M030 Sports Suspension, 997 Gear selector, and a load of other OEM styling upgrades.
Andrew McD is offline   Reply With Quote
