Old 10-26-2005, 11:59 AM   #12
Perfectlap
Perfectlap's Avatar
there is no waiting necessary for AIO. Its an acrylic so it bonds imediately to the surface. Wipe on Wipe off. Streaking may alos be in due in part to your buffing method. Never wax on wax off in circles. You should use long strokes working from left to right, a good method to preven missed areas.
When I get streaking its usually due to uneven application of AIO and not turning the polishing towel often enough. You want to make sure the surface of the towel is as free of wax as possible as you remove the AIO. I also try to avoid dry rubbing any surface. Whether is cleaning, lifting polish, or buffing, I always try to make sure the surface is wet of damp before contacting paint with towel.
BORN: March 2000 - FINLAND
