Old 05-09-2012, 07:52 PM   #2
ferrytrip1
Thanks Maurice, I had a quick look this morning before going to work. I disconnected the cables at the motor - ran it with the switch - it ran fast and smooth both ways. So that seems ok.
I pulled the inner drive cables - both are same length, both had the square drive ends so I assume they are both OK.
The top will now open and close with some hand assistance and there is still a clunking on the passenger side. The open light stays on when it is either open or closed. When closed it sounds like it is trying to finish the procedure but not quite getting there.
Tonight I will look to pull the rods and see how the top works without the xmsn to see if if it is smooth operation.
I have found a number of xmsn on e-bay - what part number should I look for and anything I should ask the seller?
Having read the posts you pointed me to I looked at the motor - is the lever that is now ziptied to he bracket off an earlier model? Mine does not seem to have it.
Simon
Simon
ferrytrip1 is offline   Reply With Quote
