Old 10-26-2005, 07:39 AM   #1
Kevlar986
Here are the instruction I follow, and have had many great comments on my finish even the dealer is impressed.
Klasse All-In-One Hand Application
1. Thoroughly wash and dry your vehicle. Remember to work in the shade.
2. If you feel any rough spots on your vehicle, you may use a clay bar to remove any surface contaminants that survived the washing process. It’s an optional step, but worth the extra time.
3. Lightly dampen a terry cloth or a microfiber applicator pad. Pour a nickel-sized amount of Klasse All-In-One on the pad and apply to one area in long, overlapping strokes. Use light pressure, but not enough to tire your arm.
4. Use a clean terry cloth or microfiber detailing towel to wipe off product, even if you can’t see residue. Complete one section before moving on to the next.
5. Your vehicle will be clean, polished and protected for 4 to 8 months.
Tip: To dampen your applicator pad, try using a quick detailing spray such as Wolfgang Instant Sealant Spritz. The lubricants in the spray will make application even easier.
Tip: It takes very little Klasse All-In-One to polish your entire car. One nickel-sized drop will cover at least half, if not your entire hood, depending on how large your vehicle is. There should be little, if any, residue left on the area after you’ve applied Klasse. If you can see it, you’ve applied too much. Spread the excess until you can’t see residue. If you try to buff an area that is still wet, it will streak.
Don’t forget you can use Klasse All-In-One on your windows, wheels, chrome, headlights, and trim. Follow the same steps. Do not use on Wind Screen!!!
Kevlar986 is offline   Reply With Quote
