Old 05-06-2012, 04:29 AM   #11
milliemax
Originally Posted by tommy583 View Post
Well i bought the car last summer. It did the same thing before i put it away for the winter. Since then i have replaced the plugs, air filter, fuel filter, clutch, IMS bearing, flushed break fluid, replaced belt and replaced AOS. If it could be the coil packs, that would seem like an easy fix. The fuel pump seems like a pain. I believe it's in the tank, i hope i'm wrong about that. My Indy has a fair labor rate, but i'd rather try to do more myself before the wife kills me.
Changing the fuel pump is not a pain. Just pay attention. After you do it once , You will say how easy it was to do. Good luck !!
milliemax is offline   Reply With Quote
