Old 04-21-2012, 11:57 AM   #26
thoward77
If your transmission is grinding or doesn't to go into 2nd during the 1st to 2nd shift when cold, get the G-Box second gear detent upgrade. As long as the problem is not severe this will fix your issue. I put one into the S over two months ago and have not had the problem again. It's even easy to install with the transmission in the car. The longer you let the grinding continue the problem, the worst it will get.
thoward77 is offline   Reply With Quote
