Old 04-19-2012, 04:11 PM   #1
Saudin801
Yes, its definitely worth doing a track alignment even with the stock suspension. Here is the series of events that I have followed over the past 16 months (new is in bold). As Topless said, its not a slippery slope, its a cliff!
1. Stock suspension, standard stock alignment, street tires. Fine for beginning track driver. As I got better/faster, I had extreme wear on the outside 1/3 of front tires.
2. Stock suspension, track alignment yielding max -1.2 deg camber in front, street tires. Much improved handling and improved grip. But again as I got better/faster, I had extreme wear on the outside 1/3 of front tires.
3. Stock suspension, track alignment yielding -1.2 deg camber in front, Nitto NT-01 race tires. Much improved grip due to the stickier tires. but the camber alignment limit casued premature/extreme wear on the outside 1/3 of front tires. Forum members (noteably Topless and Brad) predicted this would happen and they were correct.
4. Stock suspension, adustable GT-3 lower control arms, track alignment yielding -2.25 deg camber in front, Nitto NT-01 race tires. Started out with even tire wear. but as I got faster, I still have too much wear on the outside 1/3 of front and rear tires.
Next month....
5. PSS9 upgrade with adjustable sway bars, adustable GT-3 lower control arms, track alignment yielding -2.5 to -3.0 deg camber in front, Toyo RA-1 race tires. This is the Spec Box setup and I expect (hope for) better handling, more grip, and fairly even tire wear.
To the OP: sounds like you're about where I was around Step 3 so the track alignment will definitely improve things. Then prepare yourself for Step 4 or Step 5...
This is too good! I really appreciate the info.
Adjusting the stock suspension -as you clearly know- was well worth it. The car felt completely different driving home from the dealership. It has a lot more bite in the corners.
Final camber for the LF was -1.4 and RF -1.4.
Rears came in at LR at -2.4 and RR -2.6.
Who knows maybe the GT3 control arms are next.
Saudin801 is offline   Reply With Quote
