Old 10-21-2005, 08:39 AM   #1
MNBoxster
Originally Posted by deliriousga
The tool you need is in your tool kit. If you don't have it, you will need a 5mm socket with an extension to pop it loose.
Like mspell said, the instructions are in the owner's manual so let us know if you don't have one.
Also, several of us have used the Silverstar lamps (size H7 as mentioned before) and they give a brighter/whiter light. About $20 ea or $32 for a set of two at most auto shops or Walmart.
Hi,
John, if memory serves me, (and it may not), I believe it's a 7mm tool he'll need. I just use a Nut Driver, the mechanism isn't set that hard and the Nut Driver is easier to use.
Happy Motoring!...Jim'99
