Old 04-11-2012, 02:53 PM   #2
Meir
1999 base
Meir's Avatar
That is strange...
Looks like the new switch is broken as well or you plugged the connector the wrong way. (Not sure if that is possible)
The switch has two circuits, one is normally closed and the other is normally open.
You will be to check the functionality of the switch by using a volt meter.
Let me know if you need and I will try to post some pics of the process.
