Old 04-11-2012, 11:13 AM   #1
Aron in Toronto
Originally Posted by schoir View Post
Here it is, from TSB #4407, dated March 4, 1997: " Eighteen inch wheels are not approved for use on Boxsters. Use of eighteen inch wheels on Boxsters under severe conditions may result in structural failures of the body and/or suspension".
I guess the key here is "under severe conditions".
This caution was removed when the frame was reinforced in later years, but I guess that must be in another TSB.
Regards, Maurice.
This is similar to the info that I've read also, even though I use 18" wheels in the summer on my 97 w/o issues, but my driving style probably wouldn't be described as a severe condition. The PCA Boxster Tech advisor also wrote in his column that using 18" on the street would "probably" not be a problem, however using 18" (or even 17" R-compound tires) on the track may lead to trouble.
1997 Boxster
http://i40.tinypic.com/ax1qhz.jpg
Aron in Toronto is offline   Reply With Quote
