Old 04-11-2012, 03:43 AM   #1
Johnny Danger
Johnny Danger's Avatar
Originally Posted by jrcui View Post
Local craiglist ad has a set of 18" wheels from a 2002 Porsche 911 996 Carrera:
Front - 8J X 18 ET52 225/40ZR18 Continental
Rear - 10J X 18 ET65 285/30ZR18 Toyo
The price is good. Will these fit a '00 Base or require spacers.
Thanks in advance!
The fronts will fit ok . But, the offsets are not ideal . The offset on the rears, however, are way too high . Depending how "flush" you want them to look, you would have to use at least a 15 to 20 mm spacer. In addition, 285's are a bit wide for my liking; especially given the fact that the fronts are only 225's . In my opinion, that does not strike a good balance between the two .
