Old 04-09-2012, 07:43 PM   #11
Jager
Jager's Avatar
OK Danger, I just changed my Red Line motor oil and did a comparison of how much ferrous metal was on my magnetic drain plug as compared to using Mobil 1. I consistently change motor oil every 3500 to 4000 miles and ran my last oil change of Red Line 5W 40 running just over 4000 miles to make sure I had a good comparison. I can without a doubt say there is much less wear (less metal on the magnetic drain plug) using Red Line. There was approximately 50% of the ferrous metal on the magnetic drain plug as compared to the amount found using Mobil 1. I attached a couple of photos of my drain plug, one showing how much ferrous metal was on the plug while using Mobil 1 (this was a consistent amount found on multiple Mobile 1 oil changes), and the second photo shows how much ferrous metal was on the magnetic drain plug after running Red Line. Unfortunately I did not have my camera set correctly and my second photo sucks. You can still see the difference even though it’s a bad photo (I will have to make sure my camera is setup correctly next time I change my oil so I can take a better picture).
Mobil 1
Red Line
I wish I had known about Red Line 200,000 miles ago.
Quieter startups
Motor takes longer to warm-up
Less wear on the motor
Jäger
300K Mile Club
