Old 04-06-2012, 10:14 AM   #1
BYprodriver
BYprodriver's Avatar
Originally Posted by truegearhead View Post
Like most of you I'm very worried about the IMS problem. However with even the new ceramic units failing (which % failures is probably greater then the factory unit) I might choose to keep my 100,000 mile unit in. I subscribe to the theory that if a boxster survives to the 80,000 or so mile mark the inner seal has failed sufficiently for engine oil to start lubricating the bearing. As long as the engine sees high revs and keeps the oil pressure up the bearing will be ok. So if I change my bearing I might be removing a bearing thats in a good spot. Am I completely foolish? It just doesn't seem like you hear about a lot of high milage boxsters with failed IMS bearings.
Side note. I spoke with the owner of Luftechnic(a porsche only race and repair shop) here in Richmond and he told me that he does frequently replace failing IMS bearings but the failure is rarely catastrophic. Normally the cars arrive running poorly or making a terrible noise. Everything you hear about these bearings is conflicting, its frustrating.
Cheers,
I believe a PROPERLY INSTALLED LN imsb will outlast any M96/7 engine. I believe many M96/7 engines are doing ok with 15,000 mile Mobil 1 oil changes. I believe it is a wise investment to change oil every 5k miles with oil superior to Mobil 1, & have the imsb changed to LN as soon as you can afford to do so & replace worn clutch parts at that time.
